How to get at my ranchers pull start "Help"
Old Jun 9, 2003 | 09:34 PM
LAZYHammer's Avatar
Default How to get at my ranchers pull start "Help"
How do I get the plastic of to get at my pull start cord, and will it hurt anything if I try to start it that way?
Mark
Old Jun 9, 2003 | 10:01 PM
gumby's Avatar
the plastic piece comes right off just pull on it, it comes off kinda hard, no you wont hurt anything starting it that way
Old Jun 9, 2003 | 10:09 PM
LAZYHammer's Avatar
Thanks gumby, I got it, no reason at all I just wanted to try starting it that way ( just for the heck of it )
Later,
Mark
Old Oct 29, 2003 | 11:42 PM
AngryCookieman's Avatar
You use a small flat screwdriver to release the locks on the plastic rivits. Then it will come off easily. But you don't need to take the plastic off, just reach behind it and grab the handle. Once you get it out, you can start it easily with the plastic in place. Later
Old Oct 30, 2003 | 12:10 AM
Specta's Avatar
Its nice to know it works.
Old Oct 30, 2003 | 01:22 PM
swampdonkeykiller's Avatar
How do you drain the water out of the recoil? Is there a plug or something?
Old Oct 30, 2003 | 11:51 PM
There's no plug, so you'll have to run the bike till it evaporates or take the cover loose until the water drains out. If you're running in water that deep regularly, you should probably seal the whole thing off, because eventually the seal will let water in your engine.
Dammar
Nov 14, 2015 07:41 AM
Scott-Leigh
Jun 6, 2015 09:10 AM
RedRancher
Jun 4, 2015 12:29 PM
1000gade
May 27, 2015 12:37 PM
