what my 700 needs
Old Jun 9, 2003 | 09:44 PM
dillian's Avatar
Default what my 700 needs
I was in the water for the first time this summer and what happened ??
Got stuck and the belt case filled with creek water ...
The case always leaked alittle but thats the way it goes right ?
The Dealer told me that the seal on the motor side what thick felt to take the vibration of the motor ? any comments??
someone needs to make a small 12volt water pump ..lol
Old Jun 10, 2003 | 07:17 AM
Bill35's Avatar
That dont sound right Ive pulled the plug on mine a few times after riding in water all day and never got water out of it...
Old Jun 10, 2003 | 08:19 AM
Sourmash57's Avatar
dillian,
I got water in my belt casing last weekend for the 1st time. I think the clamps on the vent tube were my problem. Had the cover off changing the belt the day before and the clamps are fairly flimzy. Going to change them. Have been in much deeper stuff before and no problems. Really like that drain though!
Old Jun 10, 2003 | 10:27 AM
LaMudd's Avatar
The belt housing should not leak. If it is there is a problem. First, have you had the belt housing cover off? If yes, you may not have the gasket in properly. If no, then then the leak is eather coming from the belt exhaust, belt air intake, or the primary and secondary seals. If you want to find the leak, slowly fill the belt exhaust snorkel with water, when the belt housing fills up, it will start to leak from somewhere...that will be what to fix. Pull drain plug and go to work.
I had a leak in my belt housing after I installed my snorkels...and the leak was not coming from the snorkels. It was leaking where the belt air intake goes into the housing, tightened clamp. The seal was also leaking behind the primary clutch. I removed both primary and secondary and cleaned both seals, put some 3m marine sealent, reattached, put new gastket on belt housing, put 3m sealant around belt housing....now no more leaks. You may not have to go to this extreme...but I ride in deep water, cannot be having any leaks.
Old Jul 3, 2003 | 01:32 PM
MudMasterGeneral's Avatar
Hey LaMudd, How do you like your 28" Mudzillas? Do the rub? What kind of lift do you have? Got any pics of your bike?
Old Jul 3, 2003 | 02:49 PM
LaMudd's Avatar
this is a photo of my bike, in this photo I haw laws in the front. Depends on the bottom and mud as to which tire I like better. Laws have that huge side lug and paddle, the zillas have a larger center lug and dig...I am running both now. Laws rear, Zillas front.
I have a HL Lift, Progressive Springs, and Polaris Spring Compressors.
http://www.highlifter.com/scott_view...numrows=49&j=2
Old Jul 4, 2003 | 01:08 PM
Wicked nice bike. Why are there 2 snorkles? How much $ in extras have you got in it?
Old Jul 4, 2003 | 02:01 PM
scramblered's Avatar
it need what it always done for,the full bore size motor with the fuel injected system from the snowmobile package itself,that engine produce 48 hp.
