Most Bang For Your Buck? (raptor)
Old Jun 9, 2003 | 11:58 PM
Ugintel's Avatar
Default Most Bang For Your Buck? (raptor)
I'm looking to do some motor work to my rappy, i've got the CT HO kit on it now and I love it to death, the timing is also advanced... what else could I do and stay with in the 1,200 price range and get the most for my money? If i do much to the motor would I have to run race gas, or a mix?
Old Jun 10, 2003 | 12:08 AM
Turbo33's Avatar
You only have to run race fuel if you go with a high comp piston.
I would tell you to do suspention befor you wory about motor.
A smoother ride is a faster ride.
Old Jun 10, 2003 | 02:24 AM
UBETRUN's Avatar
Absolutely suspension upgrades, you'll only be able to use extra power after the suspension is up to speed.
Old Jun 10, 2003 | 03:40 AM
Ugintel's Avatar
i'm not track racing it tho, I only ride in the sand, i'm a light weight to, 150lbs so it's not like the bikes gona bottom out hehe..... How much more would a high comp piston give me as far as power? whats the cost on that?
Old Jun 10, 2003 | 10:34 AM
Turbo33's Avatar
Originally posted by: airraptor
for 1200 i would get a hot cam stage 2, some porting, larger intakes valves,correct springs ,new clutch and a 102mm 12-1 piston with all that you should be in the 57-60rwhp range
DIDO!!!!!!
Old Jun 10, 2003 | 11:11 AM
sixsixT's Avatar
Not bad but I think that would be about $200 over budget and if I were to build that engine I would change the rod and have the crank balanced. Another $400 or so.
So this is what I would do: 11:1, stage 1 cam, P&P, new rod and balance the crank. Then you could up grade later with the other stuff if you wanted more power. There might be a little left in the budget to get the cases machined for a later 727 upgrade if you think you might ever want to.
Old Jun 10, 2003 | 12:30 PM
Ugintel's Avatar
whats the 727 upgrade cost? and what all does in entail?
Old Jun 10, 2003 | 05:21 PM
AlaskaYFM's Avatar
Like the others have said-- aftermarket suspension goes a long way to getting that power to the ground; and once you go that route, you'll never go back.
Old Jun 11, 2003 | 12:06 AM
Ugintel's Avatar
why would a after market do any better then stock? and what would you suggest as far as a back suspension?
Old Jun 11, 2003 | 11:50 AM
Ugintel's Avatar
but will it make that big of a difference in the sand going up hills?
bmxatv10
Oct 14, 2022 06:23 PM
mrtidy
Feb 3, 2016 05:00 PM
black_thunder
Sep 22, 2015 07:59 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Alex Rodak
Sep 12, 2015 09:39 AM
