Most Bang For Your Buck? (raptor)
I'm looking to do some motor work to my rappy, i've got the CT HO kit on it now and I love it to death, the timing is also advanced... what else could I do and stay with in the 1,200 price range and get the most for my money? If i do much to the motor would I have to run race gas, or a mix?
Originally posted by: airraptor
for 1200 i would get a hot cam stage 2, some porting, larger intakes valves,correct springs ,new clutch and a 102mm 12-1 piston with all that you should be in the 57-60rwhp range
So this is what I would do: 11:1, stage 1 cam, P&P, new rod and balance the crank. Then you could up grade later with the other stuff if you wanted more power. There might be a little left in the budget to get the cases machined for a later 727 upgrade if you think you might ever want to.
mrtidy
02-03-2016 05:00 PM
Alex Rodak
09-12-2015 09:39 AM
