WARRIOR! Question
Old Jun 13, 2003 | 08:12 PM
jwwarrior's Avatar
Default WARRIOR! Question
i have a 96 yamaha warrior. the motor just started to vibrate when it gets to a certain rpm and with vibrate kinda bad. but it runs good and strong.The motor mounts are ok. ANYBODY know what might be wrong with it????!!!![img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-confused.gif[/img] Please help!
Old Jun 13, 2003 | 08:23 PM
JakalWarrior's Avatar
Are you sure the motor mounts are okay? those top ones like to shear right off. If its not that, id be a lil worried. Dunno what to tell yah. Have you recently had the clutch cover off messing with that stuff? or the flywheel side?
Old Jun 13, 2003 | 08:27 PM
Blaster96's Avatar
Please explain the viberation... are you sure the motor is in there tightly? also does it do this under load or just sitting? we need more information.
Old Jun 14, 2003 | 01:07 AM
jwwarrior's Avatar
yes ive had the clutch cover off and everything in there looked fine. havent had the flywheel cover off yet but ill check on that too.when it vibrates i can tell its not in the transmission, sounds like its in between the clutch and the head, so something could be wrong with the flywheel.You dont notice the vibration when its idleing till u rev it up cuz it only vibrates when it hits certain rpm's. i will take off the flywheel case and look at that and let u know what i find if anything.
Old Jun 14, 2003 | 01:13 AM
RaceWarrior350's Avatar
Retighten the engine mount bolts, When i put the motor back in mine it felt like the motor was gonna vibrate out of the frame, but it turned out the mounts didnt look it but were loose, take a ratchet and wrench and check all of them.
Ryan-
wendal
May 9, 2024 09:29 PM
bigred20653
Oct 2, 2015 10:05 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
