which carb for a 4x4 400 scram X
Old Jun 13, 2003 | 10:34 PM
TooFastIsBarelyEnough's Avatar
Default which carb for a 4x4 400 scram X
I was thinkin about the pwk 39 mm keihin from HPD and getting the aluminum air box but I see that alot of people have the 38 or 42mm flatslide carb. Anyone have a preferrance or know anything about differences between the two types of carbs?? any insight would be helpful thanks
2002 400 scram 4x4 HSP speed kit (pipe, clutch, K&N, outerware) billet premium head, trail tech endurance computer, pro taper bars and clamp, aluminum center skid, rear swing arm skid, 22x11x10 -10paddle extreme haulers on 8" ITP .190 wheels
LOOKING TO GET IT AS FAST AS POSSIBLE WITH THE BEST HANDLING I CAN GET
NEXT I'M GETTING carb and air box, boysen reeds, A- arm skids, bubba trail port, wiseco piston, oil injector block off
Old Jun 13, 2003 | 10:44 PM
CED's Avatar
CED
Most with mod's go with the 39PWK ,I personally have the 39 and love it.I also know alot of people that run the 42 and love it.If your gonna do any mod's either of the two would work just fine .
Old Jun 13, 2003 | 10:52 PM
do you know what the difference is between the flatslide and the pwk??
Old Jun 13, 2003 | 10:56 PM
NCScrambler's Avatar
If I could do it over again, I would go with the PWK. I would say they are almost equal performance wise, but the 38 is hard as heck to get jetted correctly and I have heard the PWK is much easier to get dialed in, I also like the way the PWK looks, it looks like a better built carb. JMO. Oh, and I do recommend the airbox, I am running it with my 38 and I love it. It flows so much better and you don't have to take half the atv apart to work on the carb!!! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 13, 2003 | 10:59 PM
ncscram did you find out if your 4x4 works properly wit hyour w/b battery eliminator??
Old Jun 13, 2003 | 11:03 PM
modquad's Avatar
Gotta go along with what the others suggested. They are all three flat-slide carbs, but the PWK is much crisper. You can get the 42 to perform kinda close, but it requires a leaner cut slide and a richer needle. Never messed with the 38, the might work o.k. on a trail mod. No matter which one you choose, take your time a do some quality jetting runs, starting out with the lower rpm range first.
Old Jun 13, 2003 | 11:10 PM
Nope not yet, I will try to find out this weekend sometime between doing a complete brake job on my truck. I will let it be known when I find out and If it doesn't work, blame it on Modquad... HEHE JK>
Old Jun 15, 2003 | 12:10 AM
I guess Modquad is safe this time!! [img]i/expressions/face-icon-small-wink.gif[/img] The 4wd still appears to be working ok with the battery eliminator.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
