02 scrambler compression?
Old Jun 14, 2003 | 12:37 PM
scrambler420's Avatar
Default 02 scrambler compression?
i have a 02 scrambler 400 2-stroke just wondering what the compression should be?i just checked mine and its reading 115 good or bad?
Old Jun 15, 2003 | 12:35 AM
NCScrambler's Avatar
115 is the minimum recommended psi on a stock engine. Remove the spark plug, add about a teaspoon of oil in the hole, and try the test again, the compression should raise and if so, your rings are worn out and you need to re-build the top-end. If you have to re-build, do not put the factory piston back in, go with a Wiseco or equivalent aftermarket piston.
Old Jun 15, 2003 | 09:32 AM
should i use the oil that im using for the gas or motor oil?im sure my dealer wont fix it under warrenty using aftermarket parts?when i first bought it he told me about the hotseat kit for it and said it would still be covered under warrenty does that sound right?
Old Jun 15, 2003 | 11:53 PM
Injection oil will work. If he said it would be covered, then it should be.
Old Jun 15, 2003 | 11:58 PM
2manytoys's Avatar
It should be covered under warranty only if it was dealer installed equipment. It is only a year old and already needs rebuild? Something is not right then.
Old Jun 16, 2003 | 01:09 PM
well its reading like 113 lbs of compression so do you think it need a rebuild?i drive it kinda hard usually half of the riding trip is wot
Old Jun 16, 2003 | 01:38 PM
2manytoys's Avatar
Sounds like your due!
Old Jun 16, 2003 | 01:46 PM
brent87LT1's Avatar
"low compression" is considered to be below 100 psi at sea level by Polaris. Yours should be fine.
Old Jun 16, 2003 | 04:03 PM
The Polaris repair manual that I have states that the compression should be a minimum of 115 psi. If you are not having trouble starting it or it running ok, then I wouldn't worry about it unless the warranty is getting ready to run out.
Old Jun 16, 2003 | 04:46 PM
i have a 5 year warrenty so im not worried about that,but as i stated in another post im having problems with it cutting out and full speed it doesnt do it all the time but enough to make me want it fixed
