Has anyone done this?
Old Jun 14, 2003 | 07:26 PM
dirtripper1's Avatar
Default Has anyone done this?
has anyone jus put on the pipe without the clutch kit, if so wat does it do like more power, less power?
and the other way around has anyone put a clutch kit on and no performance pipe, if so wat does it do more power, less power?
thanx, dirtripper1
Old Jun 14, 2003 | 07:55 PM
hotseatperformancefan's Avatar
i got just the hot seat performance pipe wit no clutch kit. and the only bad thing is that there's no low end just top end. u have to wait a second or two before it starts to hit powerband and pick up speed. but when it does if u hit a little bump or weigh enough and lean back the front end comes rite off the ground.
Old Jun 14, 2003 | 07:59 PM
Lightman02's Avatar
i have a 03 trailblazer, and i am ordering an rcr midrange pipe which supposibly gives you a great midrange for trail riding exc. it is supposed to work pretty well with the stock clutch springs + add 8 horses to the top end. i had created a thread asking ohter polaris owners if rcr is good, and they say "its one of the best out there, good choice." so i dunno, a pipe should work good with out the clutch kit, the clutch kit wont give more tp speed just a better low end.
Old Jun 14, 2003 | 08:00 PM
ftwflh's Avatar
I didnt put in a complete clutch kit all I did was put in a Polaris green primary spring and an Aaen blue secondary spring I think I did this before I put the pipe on.But with the pipe it realy kicks butt.
Old Jun 14, 2003 | 08:06 PM
hotseatperformancefan,
how loud is the pipe? i kind of like the loudness[img]i/expressions/face-icon-small-smile.gif[/img]
thanx
