clutch basket questions?
Old Jun 15, 2003 | 11:20 PM
leerjet's Avatar
Default clutch basket questions?
I have a 2001 ds 650. After adding some 22 in rear knarlys I had all the traction in the world. After a few hard rides the clutch started slipping. I sanded the the scortch off the steels and reversed the order of the clutch disks and it works great. My friend with a baja has had the same thing happen to his.He has it apart and noticed that his basket had horizontal play (pulling out on the basket). I didn't notice if mine was like that, and while he has it apart he wants to know if he should replace the basket and if so how.
Old Jun 16, 2003 | 11:00 AM
fastone21's Avatar
leerjet
Once you addeda taller tire you changed gearing. Its like running a 17 tooth sprocket lauching on pavement weighing 275 pounds. YOu need to go to a15 tooth sprocket to compensate for the taller tire and install a new clucth with 60 percent spring. All this will cost around 120.00. Hope this helps.
ghost civic
Jan 15, 2020 07:43 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
jettman
Jul 6, 2015 12:16 PM
