Predator breather line with slip on K&N
Old Jun 18, 2003 | 04:41 PM
NJRipper's Avatar
Default Predator breather line with slip on K&N
What do I do with the crank case breather when I remove the airbox with my new slip on filter? Thanks
Old Jun 18, 2003 | 07:45 PM
loneoakracing's Avatar
I own a rappy that I removed the air box. I went the cheap route and zip tied foam over the breather hose. other people buy valve cover breather filters off of a honda or other import cars. K&N also make little filters i Believe but not positive. I hope this helps you out.
Old Jun 18, 2003 | 08:25 PM
modquad's Avatar
Get yourself a K&N # 62-1010 filter, an adel clamp (rubber insulated clamp with a bolt hole to secure it), and on slightly longer screw for the throttle cable cover plate. I just routed it straight up, cut the hose to length, installed the filter, and secured it to the carb.
Jeff Roper
Feb 1, 2022 11:48 AM
Mar 21, 2016 06:30 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Elkaholic
Sep 6, 2015 02:44 PM
