Swingarm removal
Old May 11, 2000 | 03:38 PM
Dent250R's Avatar
I'm taking my swingarm off of my 86'and I can't get the pivot bolt out. I've got everything else off but this bolt. I put wd-40 all over and spun it with my impact wrench, and hit it with a sledge hammer, but it won't budge. Any help would be great.
Thanks
Old May 11, 2000 | 03:48 PM
krabill's Avatar
bigger hammer....
Old May 11, 2000 | 04:55 PM
JD250R's Avatar
My 1988 had the same problem. I had to cut the bolt between the frame and the swingarm. Then once the swingarm was off a couple taps of a hammer and a punch, it came out, along with all the needle bearings. The needle bearing cages were frozen inside the swingarm, so I had to mill them out of the swingarm. KEEP THE NEEDLE BEARINGS AND BOLT PACKED WITH PLENTY OF WATER-PROOF GREASE!! Good luck!
Old May 14, 2000 | 11:16 AM
dunerash's Avatar
I also had to cut mine out with a sawz-all..not fun.. the spacer between the bearings rust on to the bolt and they are tough to get out.. Repack it with grease and take the bolt out least once a year..good luck
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
