when i have gas turned on it cuts off trail blazer
Old Jun 19, 2003 | 03:14 PM
hebear's Avatar
Default when i have gas turned on it cuts off trail blazer
when i turn the gas on my trailblazer bogs down and cuts off when i put it on reserve it does fine do i have trash in somthing
Old Jun 19, 2003 | 03:40 PM
Polaris69's Avatar
You got a full tank of gas??? [img]i/expressions/face-icon-small-blush.gif[/img]
Old Jun 19, 2003 | 05:41 PM
NCScrambler's Avatar
If your tank is full, yes there could be some trash in the main gas line somewhere. Could be in the pick up tube or the petcock. It would be easiest to remove the gas tank and turn it upside down and see what you got, after draining the gas of course. It will not hurt anything to run it for a little whil on reserve unless the trash moves to the reserve part, then you would have possibly 2 clogs. I think it would probably be in part #20 of the following link. TrailBlazer
Old Jun 19, 2003 | 05:44 PM
mxrookie's Avatar
Dont be surprised if the petcock is installed backwards . I had one from HONDU like that .
Old Jun 19, 2003 | 05:48 PM
talonhawk's Avatar
I had the same problem on a 00 TB. It was a bad fuel petcock and had
to be replaced.
Old Jun 19, 2003 | 06:01 PM
hebear's Avatar
thanks for all the help ill check and see
skinnyr6
Aug 25, 2023 02:18 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
