210 lbs rider/best set up
Old Jun 20, 2003 | 07:03 PM
HOTRODBIFF's Avatar
Default 210 lbs rider/best set up
im running a 92 250x with 400ex a arms, what would be a good set up for trail riding, tire size,sprockets ect.
Old Jun 21, 2003 | 02:47 AM
Coyotechaser's Avatar
The size of the sprocket depends on if you want more down low power or higher top speed. At your weight you could add a tooth to the rear sprocket from stock. Larger tires will increase top speed and smaller tires will decrease top speed.
