JUst did the k&N filter with the 6 vent holes WOW
Old May 11, 2000 | 10:30 PM
Lucis's Avatar
no i can really feel the power gain with my FMF pipe but i really need to rejet it back firing bad now i did the k&N kit still dont know what jet to go with
Old May 12, 2000 | 09:13 AM
Honda1's Avatar
Start with a 158 on your 400ex. That's what I run in mine. It's still a little rich but it makes tons of power. I tried to run the 155 in it and it turned my header red, just too lean for my area. I'm at 650'.
Old May 12, 2000 | 10:30 AM
JAKOOL's Avatar
Do check your exhaust system for leaks (where the header pipe meets the silencer) they cause backfiring. You could use Chamber Seal (exhaust sealant tape available at James Lucky) to get rid of leaks.
Old May 12, 2000 | 02:49 PM
Air's Avatar
Air
Replace the flange seals with new ones. Put a light coat of ultracopper silicone on them to hold them. My guess is that one of your seals is cut or fell out.
Old May 12, 2000 | 04:15 PM
Lucis's Avatar
thannks for the info.........my pipe not leaking im just running to lean/rich what ever happen when you dont jet and put on a pipe with airfilter kit the deal told me it would backfire if i needed to jet... it did start to backfire till i did the airfilter kit was fine with just pipe .Know i can tell it running lean i think it ack like it about to run out of gas till i get on it
Old May 12, 2000 | 11:15 PM
Dirtddemon's Avatar
hey man just check the plug and you'll be set. If its black it's too rich. If it's white it's too lean. if it's tan it's right on.
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
