New Mods and a question on my 300EX
Old May 12, 2000 | 12:36 AM
tater300ex's Avatar
Well, my 2000 300 EX is all broken in. I got from a private seller a new DG Alloy pipe with Supertrapp Spark arrestor (i did not know they worked together)also a K&N Filter and a 14 tooth front sprocket. I was wondering if I need to go one size richer on my main jet. Also do you recommend adding holes to the airbox lid? Would there be problems with water?
Old May 12, 2000 | 04:05 PM
426ex's Avatar
yes you need to put in a bigger jet!!!!!
what is stock on the 300ex if it is 138 put in
a 145 and go from there. if you put in air box
vents you will have to go bigger yet.
Old May 15, 2000 | 12:01 AM
honda300ex1999's Avatar
try a 130,, my 99 is stock at 122
Old May 15, 2000 | 01:40 AM
SUP440's Avatar
Not all bikes,pipes ,mods are the same on one bike as on the other,you should only rejet if it is necessary after your current mods.Ride your bike for a few minutes and see how it responds,then check your plug.Sometimes large jetting increases are not necessary and only decrease your power.The leaner your engine can run SAFELY-not too lean-the more power it will produce,but engine damage could occur if it is too lean because of increased temperatures in the head.Too much gas(to large of a jet)could make your mods useless and actually cause a power loss.
John Reed
Sep 9, 2015 03:46 AM
bmark0610
Sep 7, 2015 09:42 PM
Wiley wolf
Sep 7, 2015 08:32 PM
JakeXBL
Sep 5, 2015 01:08 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
