High compression piston
Old Jun 22, 2003 | 03:19 PM
Pineway's Avatar
Default High compression piston
What exactly does a high comp piston do and how big is the power increase? If i put one in my engine is there any boring or re-sleeving needed? also what compresson do you recommend?
Old Jun 22, 2003 | 06:59 PM
Pineway's Avatar
come on someones gotta help me out.
Old Jun 22, 2003 | 08:24 PM
1320's Avatar
depending on what kit the may be sleeving and you gain is a few hps but 5 hp in a motor cycle is a good jump in power you will notice a differance
Old Jun 22, 2003 | 11:16 PM
UBETRUN's Avatar
A high compression piston will give better torque on the low end and, if you add a cam and porting, will give much better performance across the entire power band. I would not do a piston change without putting the money into at least a cam, the piston by itself is not a big change. You have to take your cylinder to a machine shop *with the piston* so they can bore and hone it to spec.
Divergent12
Dec 30, 2017 08:33 PM
Mikegriff92
Technical and How-To Articles
Oct 26, 2015 02:40 PM
manuelrivera
Aug 8, 2015 04:34 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Jul 29, 2015 10:57 PM
