gravity feed 86 350 ? ?
Old Jun 22, 2003 | 10:01 PM
MuddyNewf's Avatar
Default gravity feed 86 350 ? ?
Im wondering if I would be able to make my 86 350 Honda gravity feed by making a gas tank for the front rack and hooking it to the carburetor. Would this work ? Then I would have no worries about fuel pumps.
Old Jun 23, 2003 | 09:02 AM
dzzy's Avatar
probably but it sound's bogus. why don't you bite the bullet and buy a fuel pump if it's bad. they don't fail
THAT often.
Old Jun 23, 2003 | 05:54 PM
MuddyNewf's Avatar
Im not doing it cause im too cheap to get a pump its just that I want this quad to be really reliable ! I don't want to be worried out on the trail about the fuel pump going bad. I was thinking about having the gravity feed tank as a back up and to store extra gas (these things are pigs). I ride alone a lot and I don't really want to have to walk out of the woods because of a fuel pump. I wonder why Honda put a fuel pump on this model? They should have designed it with a gravity feed tank ! Oh well I still love my 86 350 lots of power for a 350 but it likes to drink a lot !
Old Jun 23, 2003 | 08:36 PM
dzzy's Avatar
It's got a fuel pump because of the location of the tank, guess that's the way it was designed. You should get years and years out of a new pump. If you choose to hook up a gravity feed set up it should work, I would run it as a spare myself tho.
Old Jun 23, 2003 | 09:03 PM
MuddyNewf's Avatar
Oh yeah I knew it had a fuel pump because there is no way they could have made the tank under the seat gravity feed. I was thinking about hooking up the extra tank for backup in case the pump goes out or if I need extra fuel. When these atvs were new did they burn a lot of fuel ? ? ? Or do you know ?
Thanks for your help !
Old Jun 24, 2003 | 07:36 AM
dzzy's Avatar
not in particular that I remember. does yours foul spark plugs?
Old Jun 24, 2003 | 05:39 PM
MuddyNewf's Avatar
Well the plugs are black ( running rich). The engine is running fine like this (lots of power). My uncle had a 86 350 for a while and it burned a lot of fuel too but ran great. It could probably be normal, my 87 Big Bear wasnt very good on fuel either.
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Canamaniac!
Sep 15, 2015 06:19 PM
