sp700 vs sp600 vs sp500
Old Jun 24, 2003 | 12:07 AM
scramblurred's Avatar
Default sp700 vs sp600 vs sp500
I was just wondering if there were any major power differences between the 700 600 and 500 ho.
Old Jun 24, 2003 | 12:14 AM
RookWV's Avatar
100cc's worth [img]i/expressions/face-icon-small-wink.gif[/img] From what I've read the 700twin is very nice on power....the 600 is basically a 700 chassis witha 600 engine
Old Jun 24, 2003 | 09:34 AM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
The 600 and the 700 are almost identical. The 500 is quite different. I would suggest the 600.
Old Jun 24, 2003 | 10:23 AM
Polaridoo's Avatar
Go with the 600. The 700 and 600 are WAY too close to tell a power difference. There is a much more noticeable difference between the 500 and the 600.
Old Jun 24, 2003 | 01:14 PM
lovemud's Avatar
The 600 might even be a little more responsive on the low end.
Old Jun 24, 2003 | 07:55 PM
carver's Avatar
they will all go 60mph+, the 600 & 700 get there quicker. the 600 & 700's also have a larger diamiter rear wheel, & i think it allows for easier sliding. a heelclicker in a 700 gives a commanding boost over the 600.
Old Jun 24, 2003 | 09:33 PM
dcatt's Avatar
I own a 600, and have ridden a buddy of mine's 700, and he rode mine, and we couldn't tell virtually any difference. The 600's motor seems to be a little smoother than the 700, and that's my buddy's opinon, and the 600 seemed to me to come in a little quicker and smoother on the bottom end, or I guess that what I'm saying is the belt seems to grab a little quicker than the 700.
From what I've read in the heel clicker's ads all they recommend is one spring to make the 600 a better mount, where the 700 requires a little more, or that's the way I understood it.
Bottom line- All three are excellent mounts, I'm sure the 700 probably has a little more top end and torque than the 600 or 500, and the 600 has more torque than the 500, but other than that they probably are pretty close.[img]i/expressions/face-icon-small-cool.gif[/img]
Old Jun 24, 2003 | 10:21 PM
mudslinger400z's Avatar
As far as pure speed goes I feel like the 500 is quicker than both the 600 or 700 but that isn't overall power. I know the 700 is a great work quad and can pull an awesome amount of weight. The 600 and 700 both weigh a ton though. I just like the 500 it's more sporty and it costs less. The 600 and 700 might be faster than the 500 but the 500 feels faster.
Old Jun 25, 2003 | 12:16 PM
lovemud's Avatar
From What I've read in this and other posts the 600 and 700 being very close in performance seems to be a reoccuring theme.
You can save about $500 by getting the 600m, And, maybe avoid waterpump problems and several other shortcomings the 700's seem to have suffered from, although most of those issue's seem to be fixed in the 04's, the 600's are easier on gas too. I guess I'm a little biased, I am VERY happy with my 600, with one exeption - the clutch needs work, I'm still not sure what to do about that.
Old Jun 25, 2003 | 12:39 PM
Polaridoo's Avatar
The 700 only had the water pump issue in '02. Everything newer was OK. The problem was not due to the fact that it was a 700, but rather the fact the cover was faulty. Also, the 600 and 700 share the same waterpump / seal components and when the 600 was introduced in '03, they already had the cover fixed.
