baja headlights
Old Jun 24, 2003 | 01:26 AM
MTRider's Avatar
Default baja headlights
Can anyone tell me where to purchase the headlight bulbs for the Baja lights?
Old Jun 24, 2003 | 02:15 AM
JMAC650's Avatar
You can get them at most auto parts stores. They are the same as most car fog lights.
Old Jun 24, 2003 | 04:51 PM
DSDuneCrazy's Avatar
They should be an H3 type bulb.
-Tom
Old Jun 25, 2003 | 02:17 AM
MTRider's Avatar
I have been trying to locate the bulbs here at the auto parts stores but I haven't had any luck. I will try the last two stores tomorrow.I have found the 55 watt bulbs but no one carries the 35 watt ones. In the parts manual there is a large red warning not to use the 55 watt so I haven't tried them
Old Jun 25, 2003 | 02:47 AM
JMAC650's Avatar
You probally wont find the 35 watt bulbs in an auto parts store. I have been running the 55 watt bulbs for over a year now and have had no problems at all. If you do go with them you have to leave the stock wattage on the headlight. You don't want to exceed the limit of the electrical system. I think it is 290 watts on the Baja but not positive. I am sure someone else on here knows for sure.
Old Jun 26, 2003 | 01:22 AM
MTRider's Avatar
Thanks for the reply. I have found the 55 watt bulb but after seeing the note in the manual I wasn't sure about using it. I will go ahead with the 55's . I should get a lot more light out of them.
akguy31
Aug 31, 2019 04:34 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Whitelx1
Oct 2, 2015 10:55 PM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
PrairieDog126
Sep 16, 2015 01:33 PM
