rear spring 01 trailboss
Old Jun 24, 2003 | 10:38 PM
thunderdaddy's Avatar
Default rear spring 01 trailboss
i am putting a stiffer spring on the boss, is the spring under alot of tension, whats the correct way to do this any help is greatly needed thanks
Old Jun 27, 2003 | 01:25 AM
SHOEFITS's Avatar
IWOULD HAVE A BIKE SHOP CHANGE SPRINGS UNLESS YOU WONT TO LOOSE A EYE
Old Jun 27, 2003 | 09:42 AM
BK's Avatar
BK
It is not hard or dangerous to change the rear spring. It can be a pain unless you have some type of spring compressor. I used 2 steel fence posts with 1 end stuck under something solid and slightly shorter than height of the spring. Duct tape on either side of shock around fence posts to hold them together and keep them from slipping. Put a little pressure down and the spring clip will be loose and you can take it off. It is a lot easier with someone helping. You might not even need the compressor for the original spring removal the TB spring is pretty soft.
Old Jun 29, 2003 | 11:44 AM
thanks BK it was very easy your right about the old spring too. i did get a compression tool that made a big differance on installing the new spring.. Ride on
68_327_c20
Nov 25, 2023 12:26 PM
merryman
Jan 19, 2016 04:29 AM
Polaris5
Aug 29, 2015 09:11 PM
binky79
Jul 30, 2015 06:37 PM
Wnthunting
Jul 9, 2015 03:02 PM
