flat-track racing
Old May 13, 2000 | 08:24 AM
Man666son's Avatar
hey i have a '93 300ex with cobra exhaust system, new jet, uni air filter, and renthals
what do i have to do to set it up for flat track
its a 1/8 mile clay oval w/ 18-20 degrees of banking
thanx people!
Old May 13, 2000 | 10:12 AM
Dirtddemon's Avatar
Sway bar and lower kits from durablue. Flat track tires. There are few out there. Hoosiers are expensive but worth it but you can comprimise for a cheaper tire that will probably work just as well.
Old May 13, 2000 | 12:42 PM
Man666son's Avatar
is it absolutly necesary to lower it?
i still want to ride it in the trails, wouldnt lowering it mess up suspention travel?
Old May 13, 2000 | 01:45 PM
Dirtddemon's Avatar
The lowering kit brings the center of gravity down so you don't traction roll so easy. The lowering kits are bolt ons they take little time to install and take off. They just relocate the shock mounts on the chassis. You don't need to lower but I wouldn't try to run with the big guys if you don't
Old May 13, 2000 | 04:16 PM
Man666son's Avatar
what about a-arms and shocks any thing there?
how much does the lowring kit and roll-bars cost?
Man666son's Avatar
how much does the lowring kit and roll-bars cost?thanx for the help so far
Old May 13, 2000 | 10:36 PM
JJFAT's Avatar
Yes, you also need a wider quad as well. Instead of wider a-arms, buy spacers for the front and back axles. That will save you lots of money. For your info, the sway-bars = $300.00, lowering kit = $150.00 (front & back), spacers = $150.00 (front & back), and tires = $350.00 thru $500.00 (front & back). I'm also looking into flat track racing, but I need some money. I hope the mentioned info helped.
Robinhood
Dec 26, 2015 10:28 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Sep 1, 2015 01:45 AM
