Scratches?!?!?
Old Jun 28, 2003 | 10:49 PM
powerstroke01's Avatar
Default Scratches?!?!?
Is there anything that will take out scratches on plastic? or at least make them less noticeable.. I have a Dark Green Outlander and its all scratched up..lol But at least you can tell it has been used..
Old Jun 29, 2003 | 01:05 AM
BigBadScrambler's Avatar
Try some stuff called Plastic Renew
Old Jun 30, 2003 | 10:12 AM
newbeatle's Avatar
Try using a heat gun for paint removal ( or a propane torch with a bit more care will work ) lightly heat up the surface of your plastic where the scratches are the edges blend together & the scratches will nearly disappear...I have head of several people having good success with this method, I haven't personnally used it but have seen the results... it will also work to a point for restoring some of the faded color on sun faded plastic as well... I don't know the long term effects of heating the plastic up to remove scratches, but the short term results are remarkable...WAM
Old Jun 30, 2003 | 06:02 PM
RideRed81's Avatar
You can try wetsanding the scratches if you want the most economical way, the plastic renew also works well and runs $15-20 for a kit. The plastic renew will be a day long task though, and if you go riding through some brush or anything it has been known to flake off.
Old Jul 4, 2003 | 05:04 PM
Blitzkrieg's Avatar
The blow torch trick works very well!!!
It even brings the color (red on mine) back.
I used some soapy water and 0000 steel wool first, then Meguirs cutting polish with a buffer, and then a light passover with the torch. Plastic looks like new.
Thanks for a great tip!
Old Jul 8, 2003 | 03:23 PM
RookWV's Avatar
Platic Repair
Old Jul 10, 2003 | 03:30 PM
it looks liek a lot of work.. Lol I dont even know if i should try.. Im thinking it will just get scratched even more later on since this will be a working bike..
Old Jul 10, 2003 | 08:45 PM
Perwho's Avatar
I thought I read somewhere that some dude was using "Lemon pledge" and he preferred the "lemon"......Dunno how good it works though????[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jul 12, 2003 | 01:03 AM
rhinhd's Avatar
I say just cover the scratches in mud!
Old Jul 12, 2003 | 03:23 AM
I wish i could find some..
nachop
Feb 14, 2018 06:57 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
papahouse
Jul 28, 2015 12:42 PM
exhonda
Mar 4, 2000 01:06 AM
