2003 spoprtsman 500 wont start-lights and gauges are all over
Old Jul 2, 2003 | 12:15 AM
uranus's Avatar
Default 2003 spoprtsman 500 wont start-lights and gauges are all over
MY ELECTIC START WONT WORK-PULL START DOES AND WHEN U PUT A SCREW DRIVER OVER THE SOLENOID IT TURNS OVER-IM THINKIN CABLE CONNECTIONS. AND O YA WHEN I GET THE SPPEDO TO STAY ON LONG ENOUGH BATTERY GAUGE IS LIKE AT 18 ND THEN WILL DROP DOWN TO LIKE 14-STILL NOT RIGHT-ITS A 12.5 VOLT
Old Jul 2, 2003 | 01:19 AM
RookWV's Avatar
Bad ground?
Old Jul 2, 2003 | 07:54 AM
ftwflh's Avatar
Try taking the wirees off of the solenoid and clean them I have had corrosion on tthe cables and did the same thing.
Old Jul 2, 2003 | 10:57 AM
lovemud's Avatar
I wouldn't worry about running at 14 V, It's not unusual to run 13 or 14. I'd be far more concerned if would be running under voltage.
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
greg86hd
Sep 16, 2015 12:32 AM
Hw00d
Sep 10, 2015 08:53 AM
chewy78
Sep 8, 2015 10:37 AM
Logan Collins
Sep 5, 2015 08:03 PM
