Alcohol Jetting
you can screw in your air/fuel mixure screw till the bog goes away. but if you are 1.5 turns or less you need drill out your pilot jet till you can get 1.5 to 2 turns out on your air/fuel screw without a BOG.
Bigger.
Bigger.
what main jet are you running?I am running a 230 main,I took my pilot completely out..are you running an accelerator pump?If so take your accelerator pump and your pilot jet out and then screw the air/fuel mixture screw all the way in and work it out until it will idle perfect and there wont be any bog at all when you give it a little gas.....
ds650racer, what do you recomend for TM48mm carb alky jetting with accelorator pump??if you have any suggestions it would be much appreciated, thanks, im at 1000ft-700ft elevation and i took the main jet out and turned air fuel mixture in all the way and backed it out a hair and it made great power but had a bog on the bottom, should i take out pilot and run 230-240 main and air fuel mix where????it ran like crap on alky at pismo, could it have beed the humidity????too much water in air?
