Alcohol Jetting
Old Jul 3, 2003 | 10:20 PM
00DSBaja's Avatar
Default Alcohol Jetting
I order a Ron Woods Alcohol Jet kit and I cant seem to get the bog out. It idles good but when you push the gas fast it has a real bad bog... Can anyone help me?
Old Jul 4, 2003 | 01:02 AM
biggerisbetter's Avatar
you can screw in your air/fuel mixure screw till the bog goes away. but if you are 1.5 turns or less you need drill out your pilot jet till you can get 1.5 to 2 turns out on your air/fuel screw without a BOG.
Bigger.
Old Jul 4, 2003 | 01:03 AM
Oh, and welcome to the forum![img]i/expressions/face-icon-small-smile.gif[/img]
Biggerisbetter.
Old Jul 4, 2003 | 08:31 PM
Ds650RaCeR's Avatar
what main jet are you running?I am running a 230 main,I took my pilot completely out..are you running an accelerator pump?If so take your accelerator pump and your pilot jet out and then screw the air/fuel mixture screw all the way in and work it out until it will idle perfect and there wont be any bog at all when you give it a little gas.....
Old Jul 5, 2003 | 10:31 PM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
ds650racer, what do you recomend for TM48mm carb alky jetting with accelorator pump??if you have any suggestions it would be much appreciated, thanks, im at 1000ft-700ft elevation and i took the main jet out and turned air fuel mixture in all the way and backed it out a hair and it made great power but had a bog on the bottom, should i take out pilot and run 230-240 main and air fuel mix where????it ran like crap on alky at pismo, could it have beed the humidity????too much water in air?
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
