raptor timing chain 686?
Old Jul 4, 2003 | 12:22 AM
Mr45auto's Avatar
Default raptor timing chain 686?
I'm just curious, my timing chain seems to be stretched a little so that my cam is about 1/2 tooth off of where it should be. My bottom end seems weaker than it should be as well. Is a half tooth enough to cause a weaker bottom end? Also should I replace it or slot my cam sprocket to make up for it?
Old Jul 4, 2003 | 12:29 AM
sixsixT's Avatar
Retarding the cam will give you less bottom end more top.You will probably need to replace the chain, I don't think you can slot the gear enough to make up that much slop and is probably weak anyway.
Old Jul 4, 2003 | 02:44 PM
Ward660R's Avatar
SixsixT is correct. I bet you are having a little hard starting problems too, right? If you replace the cam chain and gear, it needs to be as a set, it will start easier. Mine did anyway.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Dirtbikemike1
Jul 9, 2015 01:27 AM
Sjrpp
Jul 5, 2015 09:04 PM
