Kawasaki bayou 250 NEED HELP
Old Jul 5, 2015 | 09:26 PM
Sjrpp's Avatar
Default Kawasaki bayou 250 NEED HELP
So here is the problem . I recently purchased a 2007 kawasaki bayou 250 . I only payed 550$ for it because it needed some work . The day i got it home it ran fine all day long and the day after that . Then the next day i went to start it and it would bog down when given throttle . I have checked valve clearance , timing chain , drained tank flushed and put new gas in , and gone through the carb about 3 times and soaked it for about 2 hours . What im not getting is the fact that it starts up revs fine for about 10 seconds then starts bogging with any throttle this pattern repeats every time i shut it off and start it back up . Keep in mind it does smoke a bit so i didnt know if it might be low compression . I'm very mechanically inclined so any suggestion is help full .
Old Sep 17, 2019 | 04:21 PM
hack's Avatar
Some of the old Bayous eat through spark plugs. Try a new plug. see what you think.
Old Nov 15, 2019 | 09:59 PM
Jt_ardr's Avatar
I had a similar problem that ended up being a fuel flow problem. The hose supplying fuel to the carb was restricted on mine. I used a water bottle with the nipple from a bottle of gear oil to supply gas to the carb and verify that the problem was with fuel supply.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
bayou's never die
Sep 22, 2017 07:04 PM
Sjrpp
Jul 5, 2015 09:04 PM
