RR1's Break Downs at Silver Lake this week
Old Jul 4, 2003 | 01:00 AM
GregV's Avatar
Default RR1's Break Downs at Silver Lake this week
Met up with RaptorRacer1 this week at Silver Lake. The poor guy had the axle bearings go out on him and he had to drive 100 or so miles to two Yamaha dealers to find the bearings that he needed, then he had to find a machine shop to press the old ones out and install the new ones.
He also had rented a cabin to be shared by a few of his friends...........all of which ended up having to work so he was left flying solo. Bummer!
Then after a couple hours of riding he noticed that he had a header bolt that had broken off!! This was on Tuesday and he had the cabin for the rest of the week. So we went out and took a look at it. I noticed an oil line restraining bolt interestingly close to the broken header bolt and suggested finding something to attach between the two holes. Jarrod found a chain link that worked PERFECT!! We drilled out the holes in the links to accommodate the the bolts that we needed to use and installed it.
It worked out great...........salvaged the rest of the week for him to ride and not spend it running around the country side looked for someone to tap out his head.
This almost sounds like a Ward660 story. [img]i/expressions/face-icon-small-shocked.gif[/img] .........haha.........no offence Ward, but you realy do have streaks of bad luck.
GregV
On a long term basis...........has anyone had one break?? I have heard of people putting in larger studs. Does anyone have any advice for RR1 on a perminant fix?
Broken Header Bolt
Broken Header Bolt Temporary Fix
Old Jul 4, 2003 | 01:05 AM
dirtrider078's Avatar
that idea is awsome good job on figuring that out
Old Jul 4, 2003 | 01:10 AM
GregV's Avatar
Thanks dirtrider078,
There was absolutly no way that was coming off. If you look closely, you will see a nut holding the oil line against the cylinder that will also keep it from backing out.
Unfortuntly, this fix will only work if you break the exact same stud off. So, you have a 25% chance of being able to use this. ha ha
GregV
Old Jul 4, 2003 | 01:14 AM
i probly wouldent have thought of that cause i am not the type of person that can think of kinda easy fixes. i wish i was though
also what size of rim do i need to get for a 20x10x9
Old Jul 4, 2003 | 01:40 AM
GregV's Avatar
You will need a 9" rim on whatever width that you want.
When you call and order your rims they will tell you what is available for your lug pattern. Go narrower if you want a taller side wall or wider if you want a lower profile.
Old Jul 4, 2003 | 02:15 AM
ALIENraptor's Avatar
Hey man awesome save, glad he could ride. I've had that same stud break on me. A fix, I used a thicker aircraft bolt and tapped it, and used a sorta lock nut like on the axle type thing to hold it, so far so good its been about 5 months and its still going strong.
Old Jul 4, 2003 | 02:36 AM
GregV's Avatar
RR1 has his Raptor running fast for a stock engine. He just installed the Eldebrock carb set-up. It was really different. It had good power, the thumb throttle wa a bit on the harsh side, but it ran well.
Old Jul 4, 2003 | 02:49 AM
If he wants a stock fast engine, get one of sixsixt's raptor adaptors'
Old Jul 4, 2003 | 02:09 PM
87Banshee250sx's Avatar
WHoa, I didnt know RR1 had a stock engine. I thought he had 686. Hm, I feel lame. I was all excited about beatin him last time I was at SL. lol, o well.
-Nick
Old Jul 4, 2003 | 02:56 PM
Ward660R's Avatar
LOL GregV you are exactley right!!!
On the stud, I am not real sure, but I think that people are using studs from the Grizzley. Its larger and less prone to breaking. Drill out the old, tap the hole, and screw in the new studs. I think thats how I have heard it being done.
Its great ya'll patched it up! That would have been a real bummer if not! GOOD WORK!!!!
