Warrior only starts in neutral...
Old Jul 6, 2003 | 04:55 PM
00Banshee's Avatar
Default Warrior only starts in neutral...
My wife's 01 Warrior will only start in neutral. It has had the EB removed and an aftermarket clutch lever and perch installed. Is there any way to get it to start in any gear? Thanks.
Old Jul 6, 2003 | 05:24 PM
xRedxRiderx350x's Avatar
why would you or her want it to start in gear?
Old Jul 6, 2003 | 05:29 PM
rudyraptor's Avatar
could maybe be the clutch starting to go out. I had one few years ago and did the same thing
Rudy
Old Jul 6, 2003 | 05:35 PM
JakalWarrior's Avatar
Yeah, I think you pull out the clutch sensor plug and plug it into its self so it always thinks the clutch is pulled. I cant remember if you plug it into its self or leave it unplugged, but im sure you will figure it out.
Old Jul 6, 2003 | 05:42 PM
warrior007's Avatar
jakal is right
I think the EB sensor you just leave disconnected but the clutch sensor you connect the wires together. 90% sure.
Old Jul 6, 2003 | 05:53 PM
00Banshee's Avatar
I meant I want it to start in any gear with the clutch pulled in. Right now it only starts in neutral. We do a lot of duning and if she gets stuck on the side of a steep hill and the motor stalls it is a pain to find neutral. I would rather have her just pull in the clutch and start it.
Thanks for the help. I will see if I can find the clutch sensor and hook it back up.
Old Jul 6, 2003 | 07:11 PM
2000IAWarrior's Avatar
yea when u disconect the Eb brake senor thing i believe the clutch sensor is it in it to or that assebly part, buddy removed EB off rapptor and can only start in neutral..
Old Jul 6, 2003 | 11:29 PM
Just get the lil wire on the perch and follow it to the connector. The one for the e brake I think you disconnect completely. Clutch you complete the circut.
Old Jul 6, 2003 | 11:39 PM
HappaRap's Avatar
Lazy Boy Rider!
MY buddy had a Warrior, same problem finding netural is a sob, but he never starts it in gear, but I understand your point about your wife stalling on a sidehill and needing to start it up in gear. Heck the last time I stalled on a sidehill it went over and over, ouch.
Old Jul 7, 2003 | 12:13 AM
Warrior453's Avatar
hey i got a aftermarket clutch and u unplug the EB sensor then u can start it in any gear my starts in any gear and i saw this thing hangen so its prob the EB sensor unluged try it couldnt harm anything
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
1000gade
May 27, 2015 12:37 PM
2punksdad
May 23, 2000 01:46 AM
