13:1 piston for yfz 450
Old Jul 7, 2003 | 02:25 AM
iluv2fly's Avatar
Default 13:1 piston for yfz 450
I was thinking about having a 13:1 piston installed in my yfz 450 to give it a little edge over the others I run with. Anyone think this would be a good mod. Do you think it would loose any reliability.
Old Jul 7, 2003 | 02:33 AM
YFZRacer's Avatar
yah it would give you some edge get ready for race gas though
Old Jul 7, 2003 | 02:52 AM
JakalWarrior's Avatar
Could get cams while its still new so and you would save money over buying one later since you wouldnt have to buy all new stuff around it (rockers/shafts if the followers are on the rockers). They take alot less work to put in too.
Old Jul 7, 2003 | 04:15 AM
iluv2fly's Avatar
Race fuel is no problem, I had to run it in my 250r for years. 210lbs of compression.
Old Jul 13, 2003 | 04:52 PM
BigScary's Avatar
great idea ridley I never thought about that
Old Jul 13, 2003 | 04:55 PM
AlaskaYFM's Avatar
What Ridley said plus a YZF exhaust cam and you're set. I assume that you are also planning to get a slip-on exhaust and different air filter?
Old Jul 13, 2003 | 05:16 PM
iluv2fly's Avatar
Sparks exhaust on order. Still not sure about the piston. I might ride it with the stock piston this fall and during the winter put a bigbore piston in it from sparks. I am going to change the exhaust cam timing. I found out the wr and yz take the same cam they are just timed different.
Old Jul 14, 2003 | 01:33 AM
YFZn's Avatar
The YFZ, YZ, WR 450's have the same cam (lift and duration), the only diff on the YFZ,WR is the decompression pin location.
Old Jul 14, 2003 | 03:03 AM
mudslinger400z's Avatar
I have read a tester for the yfz runs this piston without race gas and it hasn't detonated the engine or no kind of problems. Now I would probably still run race but the tester said he would probably use a 50-50% race and pump gas mix.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
