Scrambler 500 4X4 Clutch Noise & Question, Picture
Old Jul 10, 2003 | 12:32 PM
Jeepman1991's Avatar
Default Scrambler 500 4X4 Clutch Noise & Question, Picture
I have a '99 Scrammy, with a HPD clutch kit. I can hear a clanking sound at idle.
Clutch View
In the pic, what is that “thingy” in the middle? I think that is causing the noise. I believe there is play in there and I am assuming that is not good.
Old Jul 10, 2003 | 12:50 PM
401's Avatar
401
That thingy in the middle is your spider.What does your outer bearing look like?The one on the far end of the clutch by the bolt.Did you re-align the "x's" on the clutch?The clutch is a balanced assembly so you must put it back together correctly.There are also (6) buttons on the outer assembly around the spider thingy that lets it slide back and forth.Check those and see if they are worn.It probably would be a good idea to rebuild the clutch.
Cole Hadden
Jun 15, 2025 09:05 AM
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 13, 2015 05:11 PM
200es
Jul 10, 2015 09:09 AM
D-Hagz
Jul 4, 2015 02:19 AM
