85 ' ATC250R Front fork oil level
Old Jul 10, 2003 | 09:04 PM
waynerod's Avatar
Default 85 ' ATC250R Front fork oil level
Hey Guys -
How much oil do you all run in your forks? My manual says fill to 7" from top of fork. I take this as 7" of air in the forks, and the rest oil... Does this sound correct? It is just that it seems kind of stiff - I haven't ridden it yet this way though.. Front brake master cylinder rebuild is in order for tonite - then riding hopefully this weekend.
One more thing - I'm planning a trip to pismo on the 25th - the first in many years. What is a good ballpark main jet size and needle setting? My bike is mostly stock. How bout' sand gearing? I'm running small turf tamers - No need for paddles for just a yearly trip..
Thanks!
Old Jul 11, 2003 | 03:27 PM
HA2's Avatar
HA2
your manuel should have the jet settings dont run 20:1 ratio (32:1 should be a good starting point and check for excessive smoking and fouled plugs) fuel and sacrifice a weekend on the stock gearing. im on the stock gearing and with the paddles i have the front end comes up when i dont want from 1-4th gear. have fun be safe dont get drunk and go swimming. [img]i/expressions/face-icon-small-smile.gif[/img]
i BELIEVE the 85's carb settings for stock are 142 main (86 is 145 with a flat slide your's is a round slide) 3rd/middle clip position dont know slow jet number.
STLyamwar
Jul 25, 2020 04:44 AM
SixSpeed5
8
Aug 2, 2015 05:38 PM
carolinabomb
Jul 26, 2015 08:40 AM
heath legg
Jul 24, 2015 01:01 PM
CRamshaw777
Jul 18, 2015 05:46 PM
