modded scram top speed?
Old Jul 13, 2003 | 05:58 PM
scrambler123's Avatar
Default modded scram top speed?
does anyone have any idea around what top speed my scrambler goes on flat asphalt? i dont have any way of finding out. my mods are listed below i weigh 160 pounds. keep in mind i have a 14 tooth front sprocket and have removed about 35 pounds from the quad. any help would be appreciated
Old Jul 13, 2003 | 06:17 PM
scramblered's Avatar
around 70 mph at wot for a long run,they don't run that more faster when modded (unless
you full trim it race mods with all the suspensions and chassis upgrades)
but they get there a lot quicker as well than stock.
Old Jul 13, 2003 | 06:31 PM
thanks scramblered any ideas if i went to a 15 tooth front
Old Jul 13, 2003 | 07:25 PM
Ronnnnn's Avatar
When you have a cvt tranny on something the only way to change your top speed is to change the gears, tires or clutching to run more rpms which will increase your top speed.
If your clutch is stock and turns 6850 with stock gearing and stock tires the top speed will be the same
no matter what you do to your engine, it will get there alot faster though.
I ran a powermax equiped sport with 14/30 gears turning 7750 last weekend and the top end was night and day difference between my trail mod with 14/34 gears turning 7100.
Old Jul 13, 2003 | 07:28 PM
i have changed my gears and clutching
Old Jul 14, 2003 | 10:26 AM
i run 13-30,and i'll go to 15-30 no problem,meanwhile you need a steeper helix to upshift the secondary as soon the gearing rato is spinning quicker.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
