advancing/retarding cams???
Old Jul 15, 2003 | 09:25 PM
Majorecho's Avatar
Default advancing/retarding cams???
Has any body tried this and had success? I was reading in the yammy forum and I guess it's a simple mod on the new 450 and I've wondered how far you could tweak the cams and still keep the valves and piston from contacting one another. I know how to experiment with them I just don't plan on pulling the head until this winter. If somebody is willing to share a success story either publicly or privetly I'll reciprocate with a power trick for them[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 15, 2003 | 09:42 PM
ScoobyDFW's Avatar
I've noticed a significant increase in topend by retarding the intake cam. (I run stock cams). The comparision was between 1/2 tooth advanced and 1/2 tooth retarded (one tooth change), which was accomplished using an 0.043" head gasket.
Valve clearance is an issue that would need to be looked at.
Old Jul 15, 2003 | 09:47 PM
Hurycne's Avatar
????? how can you retard the intake cam with an adjustable chain tensioner? I have played with the cam timing alot and the intake ALWAYS lines up.. No matter what gasket I used. Now the exhaust was that way and retarding the exhaust did increase top end for me. Advancing caused alot of poping and backfiring.
Old Jul 15, 2003 | 09:51 PM
Hurycne's Avatar
If my thinking is right you can advance the exhaust and retard the intake a good amount without valve issues but no power to gain there. I wish I had an adjustable cam sprocket cause I feel like advancing\retarding the intake would yield noticable results
Old Jul 16, 2003 | 01:21 AM
PUSHINTHELIMIT's Avatar
I have no internal engine mods yet but is there a way to get more power by moving either cam clockwise or counterclockwise 1 tooth on the cam sprocket?
Old Jul 16, 2003 | 05:06 PM
Oldmanracing's Avatar
I was understanding Scooby's theory but got lost with Hurycne's reply.
Scooby:
Could you please share a few more details so the average guy can decide if this is an area, when using the stock cams, is worth trying on a stock machine. I run a few drags and in a stock class. You got my ear and curiosity. Thanks
Old Jul 16, 2003 | 05:34 PM
I also want to know about using the stock setup as the "oldman" stated....... And me in my previous post.
Old Jul 16, 2003 | 07:12 PM
ScoobyDFW's Avatar
I don't build motors. I took the easier route, just added some back pressure.
From what I've read, advancing the camshaft in relation to the crankshaft raises torque at middle range and lower rpm. Retarding lowers the middle range and lower rpm torque but raises the top output somewhat.
My head has been machined a few times and probably has 0.0085" removed. I run an 0.043" copper gasket which is thinner than stock. I run stock cams, valves. I have a low compression 8:1 forged piston with a dish in it, so valve clearance isn't as much of an issue for me.
The cam timing is retarded due to the extra slack in the timing chain resulting from the head machining and thinner gasket. In my case the retard was around a half tooth. This will add a little power on top but take away some lowend. When I moved the intake cam 1 tooth making it a half tooth advanced I lost topend.
For a stock piston, valves, cam, head gasket, I think you would gain HP by retarding the intake one tooth, assuming valve clearance is not an issue. But if you don't want to loose any bottom end then this is not the solution. I believe someone else in the forum has tried this.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Canamaniac!
Sep 15, 2015 06:19 PM
