ideal gearing for a mojave???
Old Jul 20, 2003 | 02:30 AM
spballer's Avatar
Default ideal gearing for a mojave???
i am wondering what you guys think would be the ideal gearing for my mojave, i am mostly going to be doin trail riding, so i want to be able to accelerate pretty fast and not lose top end, i dont know how possible this is, i am totally new to the quad world. if you have any knowledge about this plz tell. thnx
Old Jul 20, 2003 | 11:53 AM
boob's Avatar
with your modifications i would go 12 in the front (stock) and 41 in the back, if you want get a 13 tooth front , doesnt loose all to much bottom end but to be on the safe side stick with the 12 front, good acceleration and good top end
Old Jul 20, 2003 | 05:27 PM
MOJAVE02's Avatar
boob in your profile it says you have a 38 tooth rear sprocket. i have searched all over and the lowest i could find was a 41 tooth rear. where'd u get it and how much was it?
Old Jul 20, 2003 | 06:33 PM
LiquidLouie's Avatar
Sprocket Specialists makes aluminum rear sprockets for the Mojave that range from 28-74 tooth. I've got a 41 and 39 on order with them. They should be at my door by the end of the week. I had to wait a little longer because I had them anodized for durability. You can also order them with additional lightening holes to save weight, or you can order them with self-cleaning grooves machined into the teeth. The website is <u>sprocketspecialists.com.</u>
Old Jul 20, 2003 | 07:03 PM
MOJAVE02's Avatar
all i have on my mojave is a white bors pipe k&n filter and it is jetted. it has 22 inch bandit tires on it. i want my top speed to be around 70mph on my mojave. is it possible to do this and still be able to climb a medium sized hill(in first gear). what size sprockets will i need to do this?
Old Jul 21, 2003 | 11:13 AM
HareScrambleRacer's Avatar
You'll be hard-pressed to see 70mph with a Mojave. Gearing alone will not acheive this feat. You'll need a Four Stroke Tech 330 kit from Mickey Dunlop. However, the following website will get you in the ballpark for speed with regard to gearing. http://www.glamisdunes.net/calculator.htmText. Primary gear = 3.050, RPM = 7500. Good luck!!
bigbear350quad
Sep 11, 2015 12:40 PM
John Reed
Sep 9, 2015 03:46 AM
awer1968
Sep 8, 2015 11:02 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
