predator at high revs
Old Jul 21, 2003 | 08:30 PM
swen's Avatar
Default predator at high revs
what is it like when you hit the rev limiter? i took it out today for a while,when i get to high revs it pops and kind of hesitates a little,is that me hitting the rev limiter quicker than i was used to because i am modded more,or is it jetting or something? it runs fine unless i hit on it hard and it gets up in the high revs,
i have to find my tach and see if i can see what number it does it at
Old Jul 21, 2003 | 11:48 PM
MudStud's Avatar
When the DS used to hit the limiter it sputterd you could DEFINATLY tell you were bouncing on the limiter... It would cut go cut go cut go......
Old Jul 22, 2003 | 02:10 PM
swen's Avatar
i suppose that means i should get the cdi before a carb?
Old Jul 22, 2003 | 02:27 PM
RaptorRider660R's Avatar
This issue has come up many times try asking Modquad, I'm pretty sure he had an answer for it.
Nocando
Old Jul 22, 2003 | 04:11 PM
aussiequadrider's Avatar
Do a search on popping.
Good luck, Geoff.
2quiker
Mar 22, 2022 08:36 PM
Steeldon
Sep 9, 2015 09:38 AM
poutlaw525
Sep 9, 2015 03:19 AM
Elkaholic
Sep 6, 2015 02:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
