BLASTER CARB PROBLEMS
Old May 20, 2000 | 06:48 PM
Rob4092's Avatar
My son has a stock 99 Blaster.
I have installed a 250 Main Jet and put the Needle on the thrid clip from the top.
The problem is, when I first begin to accelerate, it craps out and then catches up to itself and takes off.
Any advice?
Old May 20, 2000 | 07:00 PM
novaman15's Avatar
i don't know what the problem is but mine does the same thing on hot days.also does anyone know what that small flathead screw is on the left side of the carb.i messed with it thinking it was the idle screw but now don't know where it was to start with?
Old May 20, 2000 | 09:44 PM
2000_blasterboy1's Avatar
i think u are runnin rich
Old May 20, 2000 | 09:46 PM
Rob4092's Avatar
Also,
What are the following stock applications:
Needle Position.
Main Jet Size
Idle (Pilot) Jet Size
Rob4092's Avatar
Also,
Needle Position.
Main Jet Size
Old May 20, 2000 | 09:48 PM
Rob4092's Avatar
What is running rich?
The main? Needle or Pilot?
Old May 20, 2000 | 09:54 PM
BlueBlaster's Avatar
The stock jet size is a 230 and the clip on the needle is the 2nd grove from the top
Old May 20, 2000 | 10:16 PM
Rob4092's Avatar
Thanks for the info!!!
What is the Idle (Pilot) Jet stcok size?
I live in Phoenix at about 1000'.
How about the Idle (Pilot Jet)? Do you think this could be my problem? Should I increase it?
I moved the clip down to the third from the top. Do you think this is too rich?
How about the 250 Main? Too rich?
Old May 20, 2000 | 10:41 PM
fmfblaster's Avatar
i have a problem in my carb all of a suden my carb drains gas out of the over flow if you leave the gas on what may be wrong
Old May 21, 2000 | 09:58 AM
KawasakiKid's Avatar
The best carb tuning resource I've found so far is on this site...
www.bombardierds650.com
Under "What's New" you'll find a link for carb tuning. VERY informative!
Later
