Honda atc 70
Old Jul 24, 2003 | 10:16 PM
RideRedEX's Avatar
Default Honda atc 70
The problem i am having with my 70 is that it just will not fire. I put a brand new plug in and its getting good spark. Me and my friend tried pulling it behind my EX while he sprayed starting fluid in the carb with no evail. All i know is the basics, and that is if it sparks and has some kind of fuel it should fire. Can anyone help????? Thanks
Old Jul 25, 2003 | 12:11 PM
700atWASHINGTON's Avatar
You might check the timing, make sure it hasn't moved. If I remember right there were marks on the cam gear and on the flywheel that should be pointed the same direction the piston travels. Don't quote me though. I'll buy your carb if you can't get it going[img]i/expressions/face-icon-small-happy.gif[/img] J/K
Old Jul 25, 2003 | 12:22 PM
RideRedEX's Avatar
thanks i'll check that
Old Jul 25, 2003 | 12:29 PM
Raptoryfn660r's Avatar
RIP Dear Friend
Have you pulled the plug and while still attached to the spark plug wire and then grounded against one of cooling fins near bye kick the machine over and see if the plug is firing.
Old Jul 25, 2003 | 12:54 PM
RideRedEX's Avatar
The spark plug is firing great. We thought it might be the carb so we were spraying starting fluid in it. The most we got was a fire ball out of the carb and my friend dancing around with his pants on fire. I thought maybe that had something to do with timing?
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
