What P.S.I.?
Old May 21, 2000 | 09:03 AM
JAKOOL's Avatar
What would be the equivalent P.S.I. reading of a 400EX with a standard bore Wiseco 10:1 piston?
Old May 21, 2000 | 01:01 PM
minehunter's Avatar
In a perfect world, it would be 147 psi at sea level with 0 percent humidity and 59 degrees F, or if you prefer 15 C. But it's not a perfect world, so my guess would be around 130-140 at Sea level. As altitude increases the pressure will be lower.
Old May 22, 2000 | 12:00 AM
Tree Farmer's Avatar
Is that psig, or psia, minehunter? ("g" for gauge, "a" for absolute.) I don't know; at bdc, psig is zero; psia (sea level, standard temperature and barometric pressure) is 14.7. At tdc on the compression stroke? Lemme think!
You're quite correct about the imperfect world, containing ring blow-by, valve leakage; even intake valve duration sometimes affecting pressure readings.
I think your numbers, both the theoretical and the practical, are pretty close to valid.
Tree Farmer
Old May 22, 2000 | 12:43 AM
JAKOOL's Avatar
Thanks a lot guy's you helped me decide what piston to buy cause race gas is hard to buy in the Philippines.
Scott267839
Aug 3, 2007 12:13 AM
ThePunisher
Dec 12, 2003 12:35 PM
crispy
Oct 21, 2003 09:31 PM
YAMABEAN
Feb 1, 2003 01:03 AM
Addictedtomud
Jul 30, 2000 10:28 PM
