Part time 4x4 for wolverine
Old May 21, 2000 | 08:39 PM
TDC's Avatar
TDC
Has anyone thought of putting the part time diff out of the front of a 00' Kodiak on a wolverine?
I believe the gear ratios are the same, can anyone confirm this? Has anyone figured out another way to make the wolverine a part time 4x4?
Old May 22, 2000 | 12:02 AM
quad_man's Avatar
That sounds like a great idea. Mick P. who might still read the forums, at one time (before the forum software transfered over), had a King Quad differential he was trying to get to work in his Wolverine so he could have 2wd, 4wd, diff lock. I think the problem he ran into was getting the front/rear tire heights ratio to match up.
With the Wolverine and Kodiack probaly being similar, it could work! If you try it, let us know how it turns out.
Old May 23, 2000 | 12:28 AM
Thejoka's Avatar
Yep I have heard it will work. A mate has ordered the hubs and is going to give it a go. I will let you know how he gets on, but it sounds like a good project.
Thejoka
Old Jun 1, 2000 | 05:07 PM
TeamCovert's Avatar
I believe it would work the only problem I see would be that the 00' Kodiak has a strait drive shaft with no u-joints. But if you can figure out how to put a joke on the case you will have an awsome machine. Also need to find out if the gear ratios are the same.
suzuki230
Jul 8, 2016 10:03 AM
Nelson
Jun 22, 2015 03:51 AM
Nelson
Jun 20, 2015 01:59 PM
ragewraps
May 27, 2015 08:07 AM
