shock reservoir
Old Jul 27, 2003 | 02:14 PM
98cobra's Avatar
Default shock reservoir
could someone explain to me how it works? is it the more air I put in it the stiffer the shock? Do you try to match it with how stiff the rear spring is set at?
Old Jul 28, 2003 | 10:54 PM
dork's Avatar
the purpose of the reservoir is to separate the shock oil from air to prevent the oil from foaming. inside the reservoir body there is a rubber bladder that is pressurized with nitrogen to around 150-200 psi(depending on the shock). thats what the schraeder valve is for. you don't touch it except for rebuilding purposes. and it uses nitrogen instead of air because its more stable. what the nitorgen in the bladder basically does is take up the difference in space that the shock oil creates as its displaced by the shock piston.
Old Jul 28, 2003 | 11:47 PM
98cobra's Avatar
Thanks so basically I shouldn't try to fill or let out the air or touch it in general.
Old Jul 29, 2003 | 01:37 AM
dork's Avatar
yep.
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bigred20653
Sep 19, 2015 02:11 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
