200ES Big Red
Old Jul 27, 2003 | 03:09 PM
kas's Avatar
kas
Default 200ES Big Red
Looking for any information for online repair manuals or tips for this unit. Had it given to me, ran good for a couple of days but now will not start. Turns over, has spark, gets gas will not run. Any help.
Old Sep 10, 2003 | 12:42 AM
74Tx's Avatar
Have you checked compression? Have you messed around with the carb?
Old Sep 20, 2003 | 12:40 AM
kas's Avatar
kas
Have not had a chance to play with it yet but will check the compression. I have no setting etc for the carb so may have to hold off for a while on it.
Old Sep 20, 2003 | 01:38 AM
dork's Avatar
check that the plug is not fouled. the ones with high miles or ones that sat alot have a tendency to foul the plug when you try to start them. also if the battery isn't fully charged, it won't spin the motor fast enough to start it. the motor will spin pretty quick, but not quite enough to start. either charge it or try the pullstart.
Old Sep 22, 2003 | 01:05 AM
kas's Avatar
kas
Thanks for the info will give it a try.
oldschool64
Aug 12, 2015 07:13 AM
HUNTINGGRIZZLY600
ATC 3-Wheelers
Aug 9, 2007 02:58 AM
sniper84
ATC 3-Wheelers
Jan 22, 2007 09:14 PM
roadrider
ATC 3-Wheelers
Sep 20, 2004 12:25 PM
KNOWSALOT
ATC 3-Wheelers
Mar 1, 2004 01:15 AM
