I Hate Jets
Old Jul 28, 2003 | 09:45 PM
JakalWarrior's Avatar
Default I Hate Jets
Im running a 155 main, and at WOT the plug turns white. The needle is on the very top clip (super lean) but its still so rich it fouls plugs. What should I do?
Old Jul 28, 2003 | 09:52 PM
warrior86's Avatar
Default I Hate Jets
i thought if its white that means its too lean and black was rich to foul plugs. I dont know much about jettin but i think you need to go richer. dont take my word for it tho, im just learning
Old Jul 28, 2003 | 09:55 PM
vampirerider's Avatar
Default I Hate Jets
I think its true that if you have a rich running engine you should have a black sooty plug. White would seem to me to indicate a lean mixture as well, but im no professional. I hope someone else with experience can help.
Old Jul 28, 2003 | 10:00 PM
DragRaptor727's Avatar
Default I Hate Jets
yeah leans white and rich is black.
Old Jul 28, 2003 | 10:15 PM
dragracer789's Avatar
Default I Hate Jets
You NEED to go richer BEFORE YOU DRIVE IT AGAIN, or you risk melting the piston.
Try a hotter plug.
Old Jul 28, 2003 | 10:33 PM
Default I Hate Jets
What I mean is the mid range is rich and the top end is lean. I figured it out though. Too much cam overlap + not enough back pressure was messing me up. I put a piece of aluminum tape over the end of the pipe and it ran right till it tore in half.
Old Jul 28, 2003 | 10:45 PM
bandit390's Avatar
Default I Hate Jets
Jakalwarrior has the clip on the most top notch on the needle. WAYYY to lean. I even saw the plug.
[img]i/expressions/face-icon-small-frown.gif[/img]
Old Jul 28, 2003 | 10:48 PM
Default I Hate Jets
yeah yeah, you saw it after I ran around on full throttle. You didnt see the 3 I turned black testing mid range.
Old Jul 28, 2003 | 11:54 PM
RaptorRacer1's Avatar
Default I Hate Jets
I am not real familiar with the Warrior carb, but I would suggest checking your float level. If the float level is too low, it can run rich in the midrange but then on the top end, no matter how big of jet you use, there is not enough gas to feed it. I will bet that if you raise your float level a little bit it will fix the lean problem on top. Then you can work on the rich mid-range.
RR1
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
