Street bike motor in DS FRAME
Old Jul 29, 2003 | 02:38 AM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
Default Street bike motor in DS FRAME
what kind of street bike motor do you guys think would work well in the DS frame???? something with high HP and very reliable and light, i think im going to go this route, i could give the sparks boys trouble and still say it was a DS...hehehehe, thanks in advance
Old Jul 29, 2003 | 02:40 AM
ironrod's Avatar
zuki 750 - lighter than the DS, and much more power
Old Jul 29, 2003 | 09:44 AM
SANDMAN430's Avatar
isn't there a raptor with a r-1 engine running around pismo? i'd think you would want to be in that area, sad to do all that work and lose to a another quad in that arena.
Old Jul 29, 2003 | 10:11 AM
bombrider's Avatar
The sprocket side would pose a big problem
Old Jul 29, 2003 | 12:46 PM
TyreSpinner's Avatar
Definetly your best bang would be 2000 and up Suzuki GSX-R 750. Here are the specs on the motor :
Displacement : 749cc ( 45.70 cubic inches)
In-Line 4 cylinder, Dual Overhead Cam
Horsepower (crank), stock : 141 @ 12500 RPM
Torque : 83 lb. ft. @ 10500
Bore is 72mm
Stroke is 46mm
Stock Compression is 12.0:1 (Yep, on pump fuel)
Carburation : Electronic Dual-Stage Fuel Injection
4-Valve Head
Liquid Cooled
Mounted to 6-speed transmission with drive on left side.
The motor can rev to 14 000 RPM stock!
The motor itself is very very light and I see no better option for all-out power...The R1 motor has 250cc bigger displacement and puts out 150 HP @ 10000 RPM but quite some more torque at 108 lb. ft @ 8500 RPM, but, it's made by Yamaha [img]i/expressions/face-icon-small-blush.gif[/img]. And the Zuki motor is lighter.
The drive being on the left side shouldn't be too much of a problem....
Jeff
Old Jul 29, 2003 | 12:53 PM
ironrod's Avatar
Its really no problem - just flip everything over.
Old Jul 29, 2003 | 01:05 PM
PUSHINTHELIMIT's Avatar
Susuki GSXR 1000!!!! BWAHAHAHAHAHA!!!! Oh, are we worried about weight?[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 29, 2003 | 01:09 PM
the suzuki 1000 i don't think is worth it....
The 1000 is slightly stronger (19 HP more peak) but it revs considerably less and will cost you lots more than a 750...
Both engines are about the same weight...
I'd say a good Zuki 750 DS could run right next to raptor R-1 no problem....the Zuki 1000 would put you ahead of the R1 though. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 29, 2003 | 01:13 PM
True dat tyrespinner. You can also get a lot more powr out of that 750 motor...... if you dare. [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Jul 29, 2003 | 02:00 PM
ThePunisher's Avatar
You don't need the rev's! Winning a race is about displacement. The more torque you have the better. Torque wins races, not horsepower. Plus The lower revving engine will have much more reliability than a high revving one. the R-1 motor would be perfect I think. It is a little heavy but not to bad. But you want to go with a engine with fuel injection definatley.[img]i/expressions/face-icon-small-happy.gif[/img]
