ow to install a timing chain on a DS650 model 1998
[img]i/expressions/face-icon-small-confused.gif[/img] I hope that somebody can help me with this problem, I don't know how to set the timingchain does somebody know how to set the timingchain?????
Hey, thanks for your call this morning! This is the forum you want to be in -- These guys will help! Are you sure you have a 1998? The first year of production was 2000 for the DS-650 - But they should be the same anyways [img]i/expressions/face-icon-small-wink.gif[/img]
pull the valve cover, and you will see the chain then pull the side cover with the clutch cable on it, you will see where the chain goes thru there it is rather easy to figure out except there are a few torques to know but other than that easy you might want a manual for this i think there on cd for almost free if you ask around.
Some of the best illustrations for the Rotax 650 engine are Here!
Set the engine at TDC then put the exhaust cam on with the lobes facing towards the front of the quad. There should be some marks on the cam sprocket. Line them up with the head so they are parallel then, do the same for the intake cam set (lobes facing towards the back of the quad now.)
I would also suggest the Shop Manual.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
