86 350 Honda tranny trouble !
Old Jul 29, 2003 | 11:04 PM
MuddyNewf's Avatar
Default 86 350 Honda tranny trouble !
The other day I was riding towards a mud hole. I was in second gear I let off the throttle to shift to third gear. After I pulled up and released the shifter I was back on the throttle fast and hard all I could hear was a click, click, click, click from the tranny then the gear engaged and almost give me whiplash. Sometimes I have to attempt the shift twice because no gear engages. I am thinking that the shift drum might be wore. What are everyones thoughts on this ?
Thanks
Darryl
Old Jul 30, 2003 | 01:29 AM
ttyR2's Avatar
I'd drain the oil and check the filter to see if you're getting a lot of metal particles coming out. Check the clutch freeplay, if it looks good, yer probably looking at an internal tranny problem. Time to split the cases.
Old Jul 30, 2003 | 10:36 AM
MuddyNewf's Avatar
Ya I was planing on draining the oil and sifting through it ! I will also pull the filter apart and look at that as well. I am about 100 % sure its the tranny because when I can shift through the gears (most times I can) the quad pulls hard and strong. If the clutch needed to be adjusted it probably wouldn't pull as strong. I am not ruleing out the clutch just yet though.
Thanks for your help !
Old Jul 30, 2003 | 03:45 PM
biggerisbetter's Avatar
Bent shifting fork.
Bigger.
Old Jul 30, 2003 | 07:20 PM
MuddyNewf's Avatar
I was also thinking a bent shift fork ! But if it was a bent shift fork I would always have the shifting problem. The thing is sometimes it will shift fine. I find it shifts better if I shift quick instead of taking my time shifting.
bigred20653
Aug 31, 2015 12:41 PM
Haakon
Aug 24, 2015 01:54 PM
cornermike
Jul 30, 2015 06:37 AM
heath legg
Jul 24, 2015 01:01 PM
