Is this Blaster worth buying?
Old Jul 31, 2003 | 11:20 PM
96TL's Avatar
Default Is this Blaster worth buying
I know someone selling a 2001 Blaster in good shape for $1100. This is what he says is wrong with it. Think its worth buying? What do you think it would cost me to get it running? Thanks!
- Motor has 100 PSI Compression (What does this mean?)
- Needs gas tank
- Tank plastic
- Carburator Boot
Old Jul 31, 2003 | 11:23 PM
crispy's Avatar
you have to write something first[img]i/expressions/face-icon-small-tongue.gif[/img]
Old Jul 31, 2003 | 11:28 PM
crispy's Avatar
Default Is this Blaster worth buying?
sorry about that previous post by me, my thing screwed up. but i have some answers...
the motor has about 100 pounds per square inch of compression ( which means it's WAY WAY WAY time to do a new rebuild !) i wouldn't dare run it with that little compression. a good rebuild cost like 350$
gas tank is about 200$
tank plastic is just pocket change
carburator boot shouldn't be to steep do some shopping for it all.
Old Jul 31, 2003 | 11:29 PM
96TL's Avatar
Sorry about that. I hit "enter" by accident.
Old Jul 31, 2003 | 11:32 PM
96TL's Avatar
So figure it needs about $600 in work. Should I offer him less money or is that a reasonable price? It seems like it must've been heavily used for it to need a rebuild in 2 years. Think I should walk and find something else?
Old Jul 31, 2003 | 11:41 PM
crispy's Avatar
it might be over 600 but not over 700 prolly
so you put it together and figure it's going to cost you about 1700-1800$
that's pretty reasonable considering you'll be lucky to find a perfect running one for under 2 grand.
tell him you're intersted but at the same time you might could do a lil shoping around.
Old Aug 1, 2003 | 01:48 AM
Blaster200FMF's Avatar
The Blaster your looking at has bad compression , all you will need to do is the topend , , if you do it your self it will be fairly cheap lets say around $150.00 the gast tank will only cost you around 20 to 50 dollars if you like to shop on ebay or jumk yards , the plastic for the tank new are only $29 and the carb boot on ebay right now are selling for about $5.00 so with a little bit of money you will have a great quad , always check around for the best price , it will save you alot in the long run.
Old Aug 1, 2003 | 02:32 AM
CrAcKhEaD's Avatar
if the carbuerator boot is torn and he rode it like that it will have more than just top end damage, u will most likely have to replace crank and/or rod bearings which is not very fun or cheap. walk away from that one and shop around.
Old Aug 1, 2003 | 10:21 AM
96TL's Avatar
Well the carb boot isn't torn, it's missing. It could've been torn and he might've just taken it off so I wouldn't think it was ridden that way. Or somebody could've just swapped it since the bikes been just sitting around. I guess its a gamble. I'm still thinking on it. If he goes under $1100 then I'll probably buy it.
Old Aug 1, 2003 | 11:00 PM
shlekter's Avatar
whta should the compression b on a blaster??
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Aug 13, 2015 12:40 PM
315blaster
Aug 8, 2015 08:13 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
joeyupton
Jul 14, 2015 11:51 AM
