Is It Difficult To Rebuild A 4 Stroke
Old Aug 1, 2003 | 05:35 PM
shlekter's Avatar
Default Is It Difficult To Rebuild A 4 Stroke
im thinking about rebuiilding the top end on my warrior....ive rebuilt my blaster like 3 time no problem but i was womndering if it is harder because of the valves and all the other stuff in there??? and where is the adjustment screw 4 the carb on a warrior?
Old Aug 1, 2003 | 06:01 PM
JakalWarrior's Avatar
you mean the idle mixture screw? its on the bottom of the carb toward the motor. Rebuilding one isint a whole lot different than a 2 stroke except you will have to get the cam chain back on in the right place. Just make sure you have a manual and youll be good to go.
Old Aug 1, 2003 | 06:22 PM
shlekter's Avatar
Thanks 4 The Tips.....I Dont Mean The Idle Adjustment Screw I Mean Isnt There A Air Adjustment screw??
Old Aug 1, 2003 | 06:23 PM
HoundDog06's Avatar
not on a four-stroke
~HoundDog
Old Aug 1, 2003 | 06:27 PM
there is a screw but it only affects the idle. I dont mead the idle speed, I mean the idles jetting.
hwyTOhell1988's Avatar
what is a warrior motor have in it? i had to have a little help when rebuilding a DOHC 4-vavle 4-stroke but that might be a different story
Old Aug 1, 2003 | 06:59 PM
shlekter's Avatar
all i know is it is a sohc
Old Aug 1, 2003 | 07:31 PM
yaaaaaa's Avatar
I am right in the middle of doing the exact same thing you are wanting to do. You can do it all your self except u have to take it some where to get the valves taken out, you have to have a speacial hammer slide thing. I am going to say that they hardest part of it is going to be setting the timing. but its not all that hard i have been told. good luck.
Old Aug 1, 2003 | 08:30 PM
Slide hammer is cheap, but that just takes out the rocker arm shafts. I doubt youll need to replace them unless they are old as dirt or your putting in a new rocker/cam setup. A warrior motor is really simple. The head is totally self contained and comes off in one piece. When you put it on all you have to do is hook the cam chain back up and bolt it down. Ignore torque specs though, Get as close as you can but when the stuff starts to flex back off. On the little clutch cover bolts and stuff, COMPLETELY ignore torque specs unless you like to drill broken bolts out.
Old Aug 1, 2003 | 08:36 PM
shlekter's Avatar
how do u acces the clutch to replace it....dont u have to remove the whoole side cover on the engine and drain the oil.
