What happened to the lighten flywheel thread?
Old Aug 3, 2003 | 02:18 PM
Turbo33's Avatar
Default What happened to the lighten flywheel thread?
I am trying to get info on how much to lighten the flywheel and the thread totally disapeared.
Old Aug 3, 2003 | 10:14 PM
Turbo33's Avatar
Has anyone have an idea how much to lighten the flywheel?
What are the pros and cons?
Old Aug 3, 2003 | 11:01 PM
risner151's Avatar
honestly i dotn think any one has lightened their fly wheels.. right now my raptor revs like a ***** quick... and if youre not careful when cruising or takign off it will die.. so if anyhting id add weight to mine!!
Old Aug 4, 2003 | 08:45 AM
garyc660R's Avatar
Originally posted by: Turbo33
Has anyone have an idea how much to lighten the flywheel?What are the pros and cons?
The heavier flywheel requires more force too set in motion and is more resistant too slowing down. On the other hand, the lighter flywheel will rev quicker and be easier too stall. The lighter flywheel will probably make more power too a small degree due too less reciprocating weight....or parasitic loss. The crank exerts force upon the rod / piston from the side, actually trying too push the piston through the side of the cylinder. I would predict, too a small degree, less cylinder wear with the lighter crank due too less force exerting on the rod / piston and potentially more reliability....asuming the job is professionally done by someone knowledgible with this process.
Stalling would be my primary concern with this mod......in stock form the Raptor stalls easy already.
Old Aug 4, 2003 | 07:05 PM
Turbo33's Avatar
I allready have the titanium rod, I realize the Rappy stalls easy but if I can gain on the holeshot for TT racing it would be worth the risk of stalling. I run the idle a little high to help compinsate for the stalling and don't seem to have the problem.
bmxatv10
Oct 14, 2022 06:23 PM
chingchangchong
Aug 7, 2022 11:36 AM
raman8tor
Sep 20, 2015 07:35 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Elkaholic
Sep 6, 2015 02:44 PM
