Warrior Kill off
Old Aug 4, 2003 | 03:49 PM
warriorcj7's Avatar
Default Warrior Kill off
I have a warrior and was wondering if it has like a kill off switch, so when i turn it off it wont start again. Its that or i was grounding the wires and there was mud on the wires to the coil but i was thinking htat there might be a cut off switch. need help thanks!!!
Old Aug 4, 2003 | 03:54 PM
HoundDog06's Avatar
The ONLY kill switch on a warrior is the emergency kill switch located on the left handlebar just below the headlight control.
~HoundDog
Old Aug 4, 2003 | 04:40 PM
JoshCVBz's Avatar
Are you asking because it won't start? Have you checked the fuse?
-Josh
Old Aug 4, 2003 | 10:27 PM
odon1's Avatar
seen the same thing did u happen to leave the key on and the battery die try to charge it
Old Aug 5, 2003 | 03:09 PM
warriorcj7's Avatar
Nope never leave the key in but i think it was more of the mud that was up on it. it must of not had a good connection to the wire that goes to the starter. But thanks alot later
EIF
Apr 20, 2017 07:15 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
